PADS Logic의 Import시 ascii 에러
2023-03-13 23:38  |  Posted By 김민수
첨부파일
PADS Logic에서 회로도를 업체에 보내기 위해서 PADS9.0버젼으로 Export하고
VX.1.2 버젼에서 Import 하면 아래의 에러가 발생하며, 1개의 부품이 없는상태로 불러와집니다.
부품 라이브러리를 새로이 만들어 사용하여도 똑같은 문제가 발생을 합니다.
어떻게 해결해야 하나요?
Reading file --  C:\Users\minso\OneDrive\문서\AT22F_2_MAIN_MP0.2_230313_1.txt
"VENDER" MPS <MP5013AGJ>
IC105        MP5013AGJ        13600 6300    0 0 97 10 97 10 4 8 8 0 0 2
*Bad *PART* ascii data line format
"PCB DECAL" IC_MP5013A
0 60 10 0 1
1 60 10 0 1
2 60 10 0 1
3 60 10 0 1
4 60 10 0 1
5 60 10 0 1
6 60 10 0 1
7 60 10 0 1
L13789: *Part name not found IC105
IC105.4      @@@D99       4 0
L13790: *Bad *CONNECTION* ascii data line format
14600  5700
L13791: *Bad *CONNECTION* ascii data line format
14800  5700
L13792: *Bad *CONNECTION* ascii data line format
14800  5000
L13793: *Bad *CONNECTION* ascii data line format
15000  5000
L13943: *Part name not found IC105
IC105.7      @@@D94       2 0
L13944: *Bad *CONNECTION* ascii data line format
13600  6300
L13945: *Bad *CONNECTION* ascii data line format
13200  6300
L13952: *Part name not found IC105
@@@D95       IC105.8      2 0
L13953: *Bad *CONNECTION* ascii data line format
13200  6100
L13954: *Bad *CONNECTION* ascii data line format
13600  6100
L14422: *Part name not found IC105
@@@D93       IC105.2      2 0
L14423: *Bad *CONNECTION* ascii data line format
13000  5900
L14424: *Bad *CONNECTION* ascii data line format
13600  5900
L14430: *Part name not found IC105
IC105.5      @@@D112      2 0
L14431: *Bad *CONNECTION* ascii data line format
14600  6300
L14432: *Bad *CONNECTION* ascii data line format
14800  6300
L14433: *Part name not found IC105
IC105.6      @@@D98       2 0
L14434: *Bad *CONNECTION* ascii data line format
14600  6100
L14435: *Bad *CONNECTION* ascii data line format
14800  6100
L14476: *Part name not found IC105
C149.2       IC105.3      3 0
L14477: *Bad *CONNECTION* ascii data line format
13400  5600
L14478: *Bad *CONNECTION* ascii data line format
13400  5700
L14479: *Bad *CONNECTION* ascii data line format
13600  5700
L14482: *Part name not found IC105
IC105.1      R163.2       4 0
L14483: *Bad *CONNECTION* ascii data line format
14600  5900
L14484: *Bad *CONNECTION* ascii data line format
15400  5900
L14485: *Bad *CONNECTION* ascii data line format
15400  6300
L14486: *Bad *CONNECTION* ascii data line format
15300  6300
Tie-dot at 13000 5900 has less than 3 connections -- deleted.
Tie-dot at 13200 6300 has less than 3 connections -- deleted.
Tie-dot at 13200 6100 has less than 3 connections -- deleted.
Tie-dot at 14800 6100 has less than 3 connections -- deleted.
Tie-dot at 15000 5000 has less than 3 connections -- deleted.
Tie-dot at 14800 6300 has less than 3 connections -- deleted.
**INPUT ERRORS FOUND**
자세한 내용 파악을 위해 Data를 보내주시면 확인후 연락 드리겠습니다.
아래의 E-Mail로 원본 데이터를 보내주시면 감사하겠습니다
swkim@ednc.com
김민수님의 댓글
김민수  |
알려주신것 같이 Description의 Value 값이 길어서 나타나는 문제였습니다.
해당 부품의 Description의 Value 값을 수정하니 회로도가 정상적으로 Import되어집니다.
