Subtract Shapes is used to subtract one shape from another resulting in a single merged shape.
Merge Shapes is used to combine two or more shapes (copper planes or copper plane cutouts) into a single merged shape.
How to turn all 2D lines into keepout together
Subtract Shapes is used to subtract one shape from another resulting in a single merged shape. This is not restricted to copper plane cutout shapes; a copper plane shape can be subtracted from another copper plane shape.
Tip: Make sure that you are in Pour Outline mode when attempting to merge or subtract shapes. Use the modeless command PO and press Enter to toggle the setting.
Merge Shapes is used to combine two or more shapes (copper planes or copper plane cutouts) into a single merged shape. Each location where a shape intersects another shape results in a single shape that expands to include the additional shapes.
1. You must select two (or more) shapes before merging shapes.
2. The shapes need to reside on the same layer.
